VMware Live Sync Direct issue
  • January 10, 2022
  • 200 views
Hello community,
I am trying to implement Live Sync Direct between two VMware environments. Both VMware environments contains it's own Vcenter Servers and local storage. Both VMware enivornments have a virtual MediaAgent with VSA agent installed.
I’ve succesfully installed the blr drivers (VAIO) on the ESX hosts. I can configure Live Sync direct without any problems. When replicating the first VM I can see that a virtual machine is created on the target site with DR at the end as it should be. However after a couple of minutes I can see in VMware at the target site that Commvault wants to create the VM again. Because the VM is already there Commvault restarts the whole process again and after 8 minutes the same message appears again. I am using Maintenace Release 26 latest hotfixes.
Any ideas?
Best answer by Michel Kolman
Dan White wrote:
Hello @Michel Kolman
Can you please raise a support case?
Hello Dan,
This is running in my demolab right now using a NFR key. If it works fine I will implement this at customer sites.
Forum|alt.badge.img+8
  • 54 replies
  • January 10, 2022
Forum|alt.badge.img+23
  • 1292 replies
  • January 11, 2022
That’s really strange.
I wonder if you could remove the configuration, delete the VM on the destination and try configure it again?
Hello Damian,
I've already tried that and I get the same error message.
Live sync with snapshots (not Live Sync Direct) works without any problems. I only get this error with Live Sync Direct.
  • Byte
  • January 11, 2022
Hello Dan,
@Michel Kolman , were you able to get this configured at the customer site?
@Michel Kolman , following up on this one.  were you able to get this configured at the customer site?
Cookie policy
Cookie settings
