Which port need to open among CS, MA and VSAProxy to take Openstack Backup
  • February 28, 2021
  • 2095 views
Which port need to open among CS, MA and VSAProxy to take Openstack Backup.
I want to take FileSystem /DB or VM backup from Openstack Environment.
Best answer by Alireza B
Hey Kabir,
Here is what you need for OpenStack: (Port Requirements)
https://documentation.commvault.com/commvault/v11/article?p=3349.htm
dude
Forum|alt.badge.img+18
  • Community All Star
  • February 28, 2021
Make sure to always have these ports (8400/8403/8401) open as they are used by CV.
Review the Requirements for OpenStack
System Requirements for Virtual Server Agent with OpenStack
Port Requirements
  • The security group associated with the proxy instance should permit all incoming and outgoing TCP traffic.
  • If unrestricted access cannot be set up, configure a one-way Commvault firewall between the CommServe host or MediaAgent and the VSA proxy instance. With this firewall configuration, you can restrict communication to a single TCP port (typically port 8400).
TCP Ports Used for Services
https://documentation.commvault.com/commvault/v11/article?p=8572.htm
Hope it helps.
Alireza B
Forum|alt.badge.img+8
  • February 28, 2021
Hey Kabir,
Forum|alt.badge.img+24
By default, Commvault expects all ports to be open between Commvault components. You can tell it to force communication over a single port (default 8403) using network routes.
