comparison of commvault with other products
  • May 4, 2023
  • 255 views
Is there any information from a single source comparing commvault with its competitors, showing all the disadvantages and advantages?
Best answer by MFasulo
Vladimir,  there a several industry analyst that consistently compare products in our space, including Gartner, Forrester, and GigaOM that provide a multifaceted scoring against several key criteria.
Below are some links to our blogs providing the highlights, and some of them have links to the entire report, if you need a deeper dive.
Three for Three – three times in a row: Commvault Scores Highest in all 3 Use Cases in the 2022 Gartner® Critical Capabilities for Enterprise Backup and Recovery Software Solutions
Forrester Wave Data Resilience Solutions I Commvault
GigaOm Names Commvault ‘Frontrunner’ and ‘Outperformer’ in Hybrid Cloud Data Protection
MFasulo
  • May 4, 2023
christopherlecky
Challenger
Forum|alt.badge.img+16
Commvault is pretty much just awesome.
Personally I think it’s only flaw is that it requires a certain level of technical knowledge that very often simply is not dedicated to backup resources and when I refer to resources I mean people.
For plenty of administrators backup is considered an afterthought consequently Commvault may be overwhelming for everyday admins.
That said they have made alot of strides towards fixing this via the command center.
