Documentation feedback: Missing OS compatibility requirement for VM Threat Analysis
  • December 22, 2025
  • 7 replies
  • 240 views
Yassmin Omer
Apprentice
I would like to provide feedback on the documentation related to Virtual Machine Threat Analysis.
The current documentation explains Threat Analysis behavior mainly from a Linux perspective
, but it does not clearly mention OS compatibility requirements between the Threat Scan Server and the guest OS of the VM being scanned.
Based on validation in multiple environments, the following behavior is observed:
  • Linux Threat Scan Server → supports Linux VM threat analysis
  • Linux Threat Scan Server → does not support Windows VM threat analysis
  • Windows VM threat analysis works correctly only when a Windows Threat Scan Server is used
This indicates a design requirement, not a troubleshooting issue:
  • Windows VMs must be scanned using a Windows Threat Scan Server
  • Linux Threat Scan Server is intended for Linux VMs only
This requirement is currently not clearly documented, which may lead to incorrect design assumptions during deployment.
  • December 23, 2025
Hi ​@Yassmin Omer, thank you for the feedback. We’ve created a CMR for the required doc updates and will notify you once the changes are implemented.
Chandrakant
  • January 16, 2026
Hi ​@Yassmin Omer, we added a note to cover the point you mentioned, Here’s the doc link - Threat Analysis for Virtual Machine Backups.
Yassmin Omer
Apprentice
  • January 16, 2026
HI ​@csawant
Thank you very much for your support and for updating the documentation based on this discussion.
I really appreciate the effort and responsiveness of the Commvault team. This clarification will definitely help the community and avoid confusion around Threat Scan access node requirements.
  • January 16, 2026
You’re welcome.
  • February 19, 2026
@csawant  I have noticed that the Note added in 11.42 is not the same as in 11.40
https://documentation.commvault.com/11.40/software/threat_analysis_for_virtual_machine_backups.html
If we really need a Threat Scan OS matching the Guest OS then it should be correctly explained in version 11.40 documentation as current note talks about “optimal performance”
Thanks in advance!
  • February 20, 2026
Hi ​@Ledoesp, thanks for pointing this out. We’ll review the content and update it.
  • June 18, 2026
