403 random error on api
  • July 26, 2022
  • 208 views
Hi guys, could not open old thread here:
So creating new one.. Still same problem, I’ve increased debugging and file versions on webserver.log and couple more, but I think webserver.log is relevant here now as I see some strange lines in the logs.
First of all - login is actually successful, afterwards I can see connection being aborted!
login OK
Does someone have the knowledge to comment on those here?
ABORT connection
ABORT connection 2
Log lines:
18824 397c  07/26 12:52:34 ### XMLSerializer::serialize() - Serialized xml is : [<?xml version="1.0" encoding="UTF-8" standalone="no" ?><CNSession_PAbortRequest time="0"><status close="2" errnum="0" errtype="2"/></CNSession_PAbortRequest>]
18824 397c  07/26 12:52:34 ### BinarySerializer::serialize() - [<?xml version="1.0" encoding="UTF-8" standalone="no" ?><CNSession_PAbortRequest time="0"><status close="2" errnum="0" errtype="2"/></CNSession_PAbortRequest>]
18824 3224  07/26 12:53:28 ### CCvNetwork::Reset() - Network object is not disconnected. Please disconnect before deleting the network object. Aborting the connection
18824 3224  07/26 12:53:28 ### CCvNetwork::AbortConnection() - Aborting session with error : 2:0
18824 3224  07/26 12:53:28 ### CCvNetwork::SendXMLMessage() - CCvNetwork::Sending Object: CNSession_PAbortRequest, Remote Host:xxxx, Timeout:5, Flags:4, Remote Process:cvd.exe, Remote Pid:4688, Remote ThreadId:166c, Remote Service Name:JobControlCVD, Remote MAC:xxxx, Remote IP:xxxx
18824 3224  07/26 12:53:28 ### CCvNetwork::AbortConnection() - Connection aborted
18824 3224  07/26 12:53:28 ### info() - EvEvent message id - [23000777], job id - [0], flags - [2]
Was trying to google anything related to ‘EvEvent message id - [23000777]’ - but could not find anything.
Best answer by Mike Struening
Sharing case solution:
Finding Details:
- Customer is report API to extract data from multiple CommCell
- Randomly gets an error 404
Solution:
- Suggested to implement Qlogoff which customer confirmed it already part of the code
- On remote session, noticed that the login issue did not occur for multiple attmpts
- Issue seems to have resolved.
Might have to cross reference the logs from cvd and qsdk to troubleshoot this further.
You have the hostname - open cvd on that machine and filter on thread ID 166c or whatever it displays when you reproduce the error.
  • July 26, 2022
@Damian Andre
Looked into the cvd log and found this:
4688  3478  07/26 14:15:23 ### AutoDisconnect() - Handle 4574 is not disconnected by the application layer. Disconnecting the session
4688  3478  07/26 14:15:23 ### CCvNetwork::AbortConnection() - Aborting session with error : -818416048:51
4688  3478  07/26 14:15:23 ### CCvNetwork::SendXMLMessage() - CCvNetwork::Sending Object: CNSession_PAbortRequest, Remote Host:xxxx, Timeout:1, Flags:4, Remote Process:dotnet.exe, Remote Pid:18824, Remote ThreadId:4b98, Remote Service Name:, Remote MAC:3c:a8:2a:15:b6:a4, Remote IP:10.87.14.228
Also the Remote ThreadId ‘4b98’ popped up, so checked it and it also is in the filter for Remote ThreadId 166c.
Does not make sense to me :|
@benjaminas , what does CVD.log show at the time in the log file @Damian Andre posted?  CVD.log generally has no Job IDs so it’s a bit tough to make direct connections if lots of jobs are running.
Finding Details:
Solution:
