Accessing entity properties using javascript in a workflow.
  • May 9, 2023
  • 100 views
christopherlecky
Challenger
Forum|alt.badge.img+20
I am trying to create a JSON payload to submit to qoperation the problem I seem to be running into is that I can’t access the properties of the cliententity object.
I tried to see what would happen if i did something like
logger.info(servers[0].clientName)
and the output I get is null.
This is what the script looks like:
This is what the for loop looks like:
This is the output:
Clearly I am doing something wrong.
I posted this in the private area in hope it would get more traction.
Thanks.
  • May 18, 2023
Hi @christopherlecky , I am not able to see the images you attached, can you please attach once again?
