anyone using cvpysdk ? I am unable to connect to commserve, although I can ping commserve just fine
  • August 12, 2024
  • 251 views
>>> from cvpysdk.commcell import Commcell
>>> commcell = Commcell('commserve', 'admin')
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/System/Volumes/Data/apps/cv/lib/python3.12/site-packages/cvpysdk/commcell.py", line 570, in __init__
    raise SDKException('Commcell', '101')
cvpysdk.exception.SDKException: Commcell is not reachable. Please check the commcell name and services again
Best answer by mfox
Can be related to SSL connect and/or certificate.. Perhaps 2 things to further check. i.e. this error will also appear if you attempt to connect via https and certificate is expired etc.
Hello @Commvaulter2024
Try a FQDN? Just looking at examples and they all have it outlined:
https://documentation.commvault.com/2023e/essential/samples_for_developer_sdk_for_python.html
Kind regards
Albert Williams
tried FQDN. Same error message. Thanks for the link to samples though!
  • August 13, 2024
That’s it! Thank you!
I get this error every time I login through a web browser. Now how do I fix this ? :)
Not sure why it’s saying cert is not valid. It hasn’t expired yet
Issued On
Tuesday, October 24, 2023 at 10:58:50 AM
Expires On
Friday, October 23, 2026 at 10:58:50 AM
rolansaad
Apprentice
  • November 20, 2025
Try to add parameter below tro skipped the ssl certificate verification
commcell = Commcell('commserve', 'admin', verify_ssl=False)
