API Call for client license consumption
  • January 28, 2021
  • 330 views
Hi guys,
is there a easy API call where I get the license consumption for a client?
I found this API call:
{{ServerUrl}}/Client/{{clientId}}/License
But this gives me only the used license type / name e. g.:
    "licensesInfo": [
            "platformType": 1,
            "license": {
                "licenseType": 1,
                "appType": 33,
                "licenseName": "Server File System - Windows File System"
            "platformType": 1,
            "license": {
                "licenseType": 3,
                "appType": 81,
                "licenseName": "Application Class 1 - SQL Server"
My goal is to get a output like:
clientA is using 200gb of license “Server File System - Windows File System”
and
clientA is using 100gb of license “Application Class 1 - SQL Server”
Best answer by Damian Andre
Hey @Dimitri
Check out this other thread on a similar topic, the answer may be in there.
Specifically,
Under 11.22.3 I had a quick look through http://<hostname>/webconsole/api/help and found a couple that might do the trick for you:
  • GET /CommServ/LicenseUsage
    • This will get you all the usage. Looks like it’s not present in 11.20.x from my quick check
  • GET /CommcellRegistrationInformation
    • This will get you the expiry date and CCID
  • January 28, 2021
Hey @Dimitri
Specifically,
  • January 29, 2021
Hello Damian,
thanks for reply. As far as I can see this is not exactly what I need. With the mentioned queries you get the license usage from a given license. I need the client consumption in “gb” or “mb” or “tb” for any used license.
For example something like:
Client_A is using 100g from SQL License.
Client_A is using 20g from Windows File System License.
I’ll have a look on this. Thought there is an easy query to show the exact client - license consumption in mb/gb/tb.
  • January 29, 2021
Got it - yes using REST to query the results of the report could be a good way. @bish may be able to chime in more, he posted the following in the other thread:
