As Built Guide
  • February 18, 2021
  • 523 views
Do anyone know if this As Built Guide only accessible to CV SAM? I was trying to have one, but I do not see it in webconsole even after adding Additional setting under commcell property (as said in below link).
https://documentation.commvault.com/commvault/v11/article?p=37985.htm
Anuj
Best answer by Stuart Painter
Hi Anuj
Thanks for the question.
After creating the additional setting, I believe the Web Console (Tomcat) service needs to restarted to enable the As Built Report.
Please let me know if the link is displayed after service restart.
Stuart
Hi Anuj
Stuart
  • February 18, 2021
Hi Stuart,
This exactly worked. I restarted www & Commvault Tomcat Service and the link appeared under webconsole? Thank you so much  :slight_smile:
Anuj
Anthony.Hodges
Certified Expert
Forum|alt.badge.img+9
  • Certified Expert
  • February 19, 2021
@Stuart Painter  It was nice that report got a fresh coat of paint, but it would be most useful if it covered some of the newer features introduced in recent years. :pray::pray:
  • February 24, 2021
Indeed!
Hi @Anthony.Hodges, @Anuj I will follow up these requests internally with Development to see if there are any plans to update the As Built Guide.
Stuart
  • February 24, 2021
Thanks Stuart..
