Can someone tell me what is wrong with this workflow script activity?
  • August 11, 2022
  • 83 views
chrisknows
Explorer
Forum|alt.badge.img+9
I have a short script activity that checks the output of a powershell command, as far as I can tell it works perfectly but when I run “check syntax” it gives me a lexical error.
Best answer by Sunil
Hi @chrisknows
Please try
update == “add” instead of ‘add’ in line number 11. (Double quotes).
Sunil-
Sunil
Forum|alt.badge.img+16
  • August 11, 2022
Hi @chrisknows
Please try
Sunil-
chrisknows
Explorer
  • August 11, 2022
Unbelievable, that worked. Thank you.
Sunil
  • August 11, 2022
Great!!
