Just to verify.
The subjected workflow only exports settings for a stg policy but no action is done on the source commcell. Hence all backups etc.continues to work as before?
//Henke
Answer
CCM-ClientByStoragePolicy WORKFLOW
Best answer by Mike Struening
Hi
If you migrate a client over, my expectation would be that the client is now backing up on the source CommCell, not the old one unless you have some multi instancing setup (along with clever scheduling to avoid conflicts).
What is your end goal with the clients being migrated?
