Commserve Standby unattended installation
  • February 23, 2022
  • 266 views
Robert Horowski
I’m trying to record answer file for Commserve Active and Passive unattended installation. Unfortunately when I create custom package for CS with Failover it doesn’t ask whether it’s for Active or Standby Commserve, so the answer file I got allows me only to install Active Commserve.
Is it possible to create answer file for Stanby Commserve installation?
Best answer by Juan Rosas
Hi @Robert Horowski
Please review the documentation below for such task
Unattended Installation of CommServe LiveSync Setup
https://documentation.commvault.com/11.24/expert/115848_unattended_installation_of_commserve_livesync_setup.html
Standby CommServe Host
Verify and ensure that the production CommServe host installation is successfully completed before installing the standby CommServe host.
Copy the custom package to the server in which you plan to setup a standby CommServe host.
Navigate to the location where the custom package was copied, and install the packages in the silent mode using the following command:
setup.exe /silent /play install.xml /standbynode /activecshostname <Production_CS_hostname>
Forum|alt.badge.img+5
  • February 23, 2022
Hi @Robert Horowski
Robert Horowski
  • Community All Star
  • February 24, 2022
Hi @Juan Rosas
I’m not sure how did I miss that, but I was able to do what I was aiming for following your advise an provided article. Thank you!
