Commvault integration with Morpheus
  • September 25, 2024
  • 387 views
Hi All,
I'm looking for technical resources and experience in integrating Commvault with Morpheus.
What is the integration architecture?
Is it possible to match tenant between Morpheus and Commvault? If so, how?
So far, I've found only one link on the subject at Morpheus:
Commvault — Morpheus Docs documentation (morpheusdata.com)
In the integration section of this link, it says to add the IP or Hostname of the CommServe”, but I'm under the impression that it refers to the Web Server (in our architecture, the Web Server is not hosted on the Commserve).
Luc
Hello @luhenn
In that configuration Morpheus is aware of Commvault but Commvault does not know anything about Morpheus. From the Commvault side of things it is just another client like any other and not treated any differently to be protected.
In regards to if you need to use the CS IP or the webserver IP, i wouldn't know the answer but just given them both a try and see which one works. Not to sure.
Might be a better question for Morpheus then Commvault if they have specific requirements.
Kind regards
Albert Williams
  • September 30, 2024
Hello Albert,
Thank you so much! I'm actually going to work on the Morpheus side:
Morpheus Plugin Documentation (morpheusdata.com)
Backups Plugin
Backups are a big part of self-service workload management. Allowing a customer to back up their application and especially restore it on the fly are critical to creating a complete self-service solution. This is why Morpheus integrates with several best-in-class backup solutions like ... Commvault. Morpheus even provides its own basic backup providers for those customers still looking for a final solution.
Latest Plugins topics - Morpheus (morpheusdata.com)
Best  regards,
Luc
Hello @luhenn
Thanks for the update and that context makes your question make more sense!
I will have a chat internally on this side and get someone to reach out to you.
Kind regards
Albert Williams
Forum|alt.badge.img+20
  • Challenger
  • May 12, 2026
Hi all,
Using this thread about Morpheus, as I cannot find the full details in Commvault docs and HPe docs.
I am looking for the detailed rights that are required for the account that will be used to access the Morpheus Hypervisor, to perform all the backup/restore operations.
Arlie mentions some ‘high level’ rights, but these I cannot find in the HPE Morpheus hypervisor rights management page, section by section, right by right.
Example :
I guess this SNAPSHOTS / Snapshots right requires more than READ.
There are other sections like INFRASTRUCTURE, with subsection Compute, that may need more than READ?
Anyone using HPE will be able to see this.
We cannot provide ‘full admin of everything’ to such account that would be only be used by Commvault. Noone does this in a serious company nowadays 😁
Maybe a common document for this part by Commvault and HPe would be necessary.
Thanks !
Laurent.
