Commvault integration with Tensai automation tool
  • August 2, 2022
  • 7 replies
  • 110 views
Hi All, please let me know if anyone worked on integrating COmmvualt API’s to Tensai tool for any backup job status or anything else.
Best answer by Collin Harper
@S7_Venkat
Thank you for your patience. We have no documentation on the Tensai Tool, but you can use REST API’s to integrate with other software. Below is our documentation on REST APIs that may be helpful with integrating Commvault into your monitoring tool.
https://documentation.commvault.com/11.26/essential/45540_rest_api_overview.html
Thank you,
Collin
Hello @S7_Venkat
We do not currently have any Commvault branded documentation regarding Tensai. Can you elaborate on what you are trying to accomplish with this integration?
Thank you,
Collin
  • August 2, 2022
hi @Collin Harper , we are trying to get the backup success rate, failure information and etc for reporting purpose.
@S7_Venkat
Have you considered using Commvault’s Command Center to monitor your environment?
Command Center has built in metrics and on-demand reports you can run to monitor the health of jobs, deduplication, index, and various other aspects of your environment.
https://documentation.commvault.com/11.26/essential/130995_command_center_and_web_console_reports.html
https://documentation.commvault.com/11.26/essential/103702_dashboards_on_command_center.html
https://documentation.commvault.com/11.26/essential/39287_managing_reports.html
Thank you,
Collin
  • August 2, 2022
this is new requirement to have a centralized dashboard due to various backup tools in the single environment.
  • August 4, 2022
@S7_Venkat
Thank you,
Collin
  • August 4, 2022
hi Collin, thanks for the follow up and information. I had same information and were able to perform test authentication between Postman and Commvault using API’s successfully, we are exploring the connectivity between Tensai tool and Commvault.
thanks again.
@S7_Venkat
You’re welcome! I am happy to hear things are working.
