Continuous Data Replication (CDR) and Network Topology
  • May 7, 2024 8:42 AM UTC
  • 35 views
is it possible to run continuous data replication (CDR) using the Network Topology functionality? The point is that the source and destination servers are in different network segments and do not communicate with each other - but both communicate with MediaAgent. Is it possible to setup such configuration to perform replication using gateway (MediaAgent)?
Regards Dorothy
Yes CDR should honor network topologies - so you can configure the media agent as a network gateway to act as a proxy between CDR targets
