Creation Authtoken and accepting it
  • February 27, 2024
  • 84 views
Forum|alt.badge.img+13
Hi Team,
I'm very new to the Rest API, but I was only able to create an authtoken :) As far as I learned, when the authtoken is created, the max. It can be used for 30 days. After this period, it is necessary to create a new authtoken and use the new authtoken. We are thinking something like this, Is it possible to do this?
We are trying to create a powershell script, this script will create a new authtoken every time it runs and will automatically use the new authtoken, then we will be able to GET the information we want from Commvault. Rest
  • February 27, 2024
Timeout is defaulted to 30 minutes. You’ll want to create a token for minutes in 30 days by adding timeout to the body of your request.
Login | Commvault®
  • timeout integer
    Default value: 30
    Timeout of the token in minutes
