Custom Alert
  • May 28, 2024
  • 61 views
Hello all,
I search to create a SQL alert in order to notify me if an agent have no schedule policy associated.
I found an sql query…. but not sure of it. Can you help me ? Thank you !
use commserv
select distinct CommCellSubClientConfig.clientname, CommCellBkScheduleForSubclients.scheduePolicy, CommCellBkScheduleForSubclients.scheduleName, CommCellBkScheduleForSubclients.schedbackuptype
from CommCellSubClientConfig
join CommCellBkScheduleForSubclients
on CommCellSubClientConfig.appid = CommCellBkScheduleForSubclients.appid
Erase4ndReuseMedia
Are you set on having an Alert? Given that removing subclients from schedules is part of your standard workflow, I would be concerned about the amount of noise generated by such an alert.
I would instead recommend tuning the Subclient Schedule Information report to show only SQL Subclients that have no Schedules, and then scheduling that report to send at an appropriate time.
