custom report
  • January 29, 2025
  • 60 views
Hi Community
does anyone have a custom report they are willing to share that shows only synthetic_full backups that have failed in the last week?
More specifically i am looking for a report that outputs just a list of servers with failed synthetic jobs over that last week. nothing else.
with the standard reports it shows all sorts of information, like generated on date, or report criteria, and all sorts of details that makes it very difficult (not to say impossible) to convert into a ticket.
Mohamed Ramadan
Explorer
hello ​@Carsten
Are you looking for something like this?
https://cloud.commvault.com/webconsole/softwarestore/store.do#!/135/660/29964
Mohamed Ramadan
Data Protection Specialist
  • January 29, 2025
Well yes, and no.
in order for the report to be digested into our ticketing system automatically, only relevant information needs to be in the report.
So something like
server1
server2
server3
and nothing else, not graphs, or other fancy things.
  • January 30, 2025
As far as I know, you should be able to modify the columns and save it as a view, then schedule the report on that view and only the required information should be received.
Sending the report on CSV format should skip the graphs
