cvpysdk - lists all backup jobs history from specific client
  • July 28, 2024
  • 146 views
Forum|alt.badge.img+2
Can someone knows on how to lists all the subclient backup jobs history using cvpysdk?
Any sample syntax that we can follow?
  • July 30, 2024
Please follow the below steps:
“””The below is for a specific subclient”””
from cvpysdk.commcell import Commcell
c = Commcell("<cs-name>", "<username>", "<password>")
cl = c.clients.get("<client-name>")
agent = cl.agents.get("<agent name>")
backupset = agent.backupsets.get("<backupset name>")
subclient = backupsets.subclients.get("<subclient name>")
>>> subclient.subclient_id
'6653' # subclient id
entity_dict = {" subclientId": <id of the subclient>}  #dont give single or double quotes here
job_controller = c.job_controller
job_controller.finished_jobs(client_name="<client name>", lookup_time=<number in hours>, job_filter="Backup,SYNTHFULL", entity=entity_dict) # dont give single or double quotes in number in hours, lookup_time is to get all the jobs executed within the number of hours
If you only want to filter by client then follow these steps:
job_controller.finished_jobs(client_name="<client name>", lookup_time=<number in hours>, job_filter="Backup,SYNTHFULL")
Example:
>>> cl = c.clients.get("san-desh")
>>> agent = cl.agents.get("file system")
>>> backupset = agent.backupsets.get("Test_48744")
>>> subclient = backupsets.subclients.get("default")
'6653'
>>> entity_dict = {"subclientId": 6653}
>>> job_controller.finished_jobs(client_name="san-desh", lookup_time=500, job_filter="Backup,SYNTHFULL", entity=entity_dict)
Output:
{666639: {'operation': 'Backup', 'status': 'Completed', 'app_type': 'Windows File System', 'job_type': 'Backup', 'percent_complete': 100, 'pending_reason': '', 'client_id': 1763, 'client_name': 'san-desh', 'subclient_id': 6653, 'backup_level': 'Full', 'job_start_time': 1720595206, 'job_elapsed_time': 1906}}
  • August 2, 2024
Hi @Swatish , Just got back here. I will try your recommendation and it seems good.
Appreciate your help. Thank you!
  • August 2, 2024
Hi @Swatish I tried it just now and it works!
I need to think of way on how to make the dict format converted into csv or table format just like what we can see in the Backup job history from the console.
