Defining Filters for a Subclient (VMware command line)
  • April 22, 2025
  • 71 views
I see that  update_subclient_filters_template.xml allows for specific VMs to be added to filters but can it also be used to remove them?  I tried changing  -vmFilterOperationType ADD to DEL or REM but no luck.
Best answer by Jon Vengust
Hi JDods,
I believe we use the following values for the operation types:
  • ADD - Add filters.
  • OVERWRITE - Overwrite existing filters.
  • DELETE - Delete the filters.
Can you retry the command with these operation type values and report back?
Jon Vengust
  • April 23, 2025
Hi JDods,
  • April 23, 2025
DELETE worked!  Thank you.
