DELETE SCHEDULE POLICY USING PYTHON OR POSTMAN REST
  • Feb 20, 2024 1:52 PM UTC
  • 9 replies
  • 95 views
Hello Vaulters,
I have been to automate schedule policy delete using by calling the API using the syntax on the document but I keep facing error, does any one have an already executed script or guide and how to achieve this?
  • Feb 20, 2024 1:58 PM UTC
Uchenna,
What is the error that you are getting.
Edward J Holowienka
  • Feb 21, 2024 8:04 AM UTC
Hello Edward
se error attached
  • Feb 21, 2024 1:26 PM UTC
Uchenna,
Where did you get the values 54656 and 54942 from.
Reqards,
Edward J Holowienka
  • Feb 21, 2024 1:42 PM UTC
Hello Edward,
This is 54656 represent the Schedule task ID and 54942 represent the sub taskID gotten from the postman syntax
  • Feb 21, 2024 2:28 PM UTC
Uchenna,
You need to get those values from your environment by running the following;
To get the taskid
GET <webservice>/SchedulePolicy HTTP/1.1
Then you would need to run this to get the subtaskid
GET <webservice>/SchedulePolicy/{taskId} HTTP/1.1
Reqards,
Edward J Holowienka
  • Feb 21, 2024 2:47 PM UTC
Hello Edward,
Exactly what I did but do you have the syntax to delete a schedule policy?
  • Feb 21, 2024 3:32 PM UTC
Uchenna,
Based upon the error that you are getting one of the values is not correct. Do you want to delete the whole schedule policy or just one of the schedules within it.
Edward J Holowienka
  • Feb 21, 2024 3:41 PM UTC
Hello Edward,
  • Feb 21, 2024 3:56 PM UTC
Uchenna,
If that is the case, then this is the call that you should be using
https://documentation.commvault.com/2023e/essential/rest_api_delete_schedule_policy.html
DELETE <webservice>/SchedulePolicy/{taskId} HTTP/1.1
Edward J Holowienka
