Draw.io stencils
  • Jan 21, 2025 8:11 PM UTC
  • 2130 views
dude
Forum|alt.badge.img+20
  • Community All Star
I am looking for stencils that can be imported into draw.io to build backup diagrams and environments for documentation purpose.
Is this something Commvault has available to customer? If so, can you send a link for download please?
Thank you
Best answer by Rajiv
Hello ​@dude For downloading Commvault-specific Visio stencils, you can access them from the Partner Advantage portal under Technical Enablement | Technical Toolbox if you have access. If you do not have access, you may contact Commvault support or sales teams who might be able to provide the necessary stencils.
https://partners.commvault.com/PRM_PartnerHome?startURL=%2FPRM_Tools_Toolbox
Best,
Rajiv Singal
Rajiv
  • Jan 22, 2025 11:42 AM UTC
Best,
Rajiv Singal
Hi Rajiv,
I did not find any Visio stencils within the link that you provide, can you be more direct, I have the old stencils form 2020 and I'm looking the new Commvault marketing image.
many thanks,
Miguel Valls
Onno van den Berg
Forum|alt.badge.img+24
If you search for the word stencil in the partner portal you will find the link to the Vision stencils.
Lukas3D
Explorer
Forum|alt.badge.img+13
  • Jul 29, 2026 12:01 PM UTC
Not everyone is a partner, many administrators and architects create diagrams for both internal and external purposes. Why doesn’t Commvault simply add stencils to draw.io (app.diagrams.net now) and make the Visio stencils available through a public link?
