Flag in API to enable WORM
  • Jun 20, 2024 6:50 AM UTC
  • 65 views
Forum|alt.badge.img+2
So far we’ve utilized non-worm server plans for VM group and SQL instance backups via Equivalent API.
Is there any approach in API to enable Worm flag.
Any suggestions would be greatly appreciated.
Hello @bpanda
The following should get you want you need:
https://api.commvault.com/docs/SP34/api/cv/OpenAPI3/get-backup-destination-details#get-backup-destination-details-of-serverplan
It has the flag “wormStoragePoolFlag": 0,”
Kind regards
Albert Williams
  • Jun 21, 2024 11:33 AM UTC
Thank you, Albert.
Above link is explained to get details of backup destination details of server plan.
We need it for creation or update of backup destination details.
