Get custom fields from API response?
  • Nov 1, 2024 7:27 PM UTC
  • 117 views
I am calling ‘/Job’ API with different offset and a 5000 limit to get all the backup jobs from commserve. However, I don’t need all the fields and only job status, id, time and a few others.
Is there any way I can limit the fields returned in the API?
Forum|alt.badge.img+2
  • Nov 4, 2024 11:34 AM UTC
Hi @Prashant Mall
While we may not have control over the API response, but we can parse it to suit our needs.
Sample code in Python
import requests
import json
import pandas as pd
url = "https://<Webserver>/commandcenter/api/job"
payload={}
headers = {
  'Accept': 'application/json',
  'Authtoken': <TOKEN> //Replace with Token
response = requests.request("GET", url, headers=headers, data=payload,verify=False)
data = json.loads(response.text)
jobs_data = [(job['jobSummary']['jobId'], job['jobSummary']['status']) for job in data['jobs']]
df = pd.DataFrame(jobs_data,columns=['Job ID', 'Status'])
print(df)
df = pd.DataFrame(jobs_data,columns=['Job ID', 'Status'])  : here you can add/remove column names according to your needs.
Hey! I am already doing that, but I am pulling all backup jobs and there are thousands of servers in our environment. The response payload is huge with many properties I really don’t need. It takes hours to collect the data and thus am wondering if there’s an option to set the properties I want in response of the APIs.
Forum|alt.badge.img+8
  • Nov 27, 2024 2:58 AM UTC
Hi Prashant,
An alternative option you could consider is creating a custom report or shared dataset that returns just the fields you want and use the /datasets API to retrieve the results. REST APIs for Reports
