GETTING STARTED WITH ANSIBLE AUTOMATION ON COMMVAULT
  • June 22, 2022
  • 4451 views
Hello Community,
How do I get started with automation on commvault?
What are the pre-requisites and basics steps to installation?
For those using Ansible to autmoate on commvault is this preferable than performing operation directly from the commcell console?
Best answer by Vairavaprakash
Hi @uchenna kanu,
Automation - https://documentation.commvault.com/11.24/expert/92328_automation.html
CVPySDK - https://github.com/Commvault/cvpysdk
Ansible - https://github.com/Commvault/ansiblev2
Please refer to the above documentation to get started with Automation and Ansible.
Ansible is still in starting phase, the list of supported modules can be found here https://github.com/Commvault/ansiblev2#modules
Hello @uchenna kanu , thanks for the post!  I’m going to look into what docs we have available, though I’m tagging in @Sachin as well.
Hi @uchenna kanu,
Hi @uchenna kanu  -- please let me know if the ansible modules are present for metallic.io also. we want to explore metallic.io for backup solution hence checking for any ansible modules present for the metallic.io.
Please send me the document reference or any whitepapers, blogs etc will also help.
Regards
Narendra
Onno van den Berg
Forum|alt.badge.img+24
@Narendra Thapa The ansible modules should work on both Metallic and you own environment as both shares the same code base. Commvault is also merging both worlds together thereby creating one holistic platform that cover both words with a single API.
