Answer
Have a Report run after a specific SubClient Job runs each day
  • May 13, 2022
  • 110 views
I have a subclient job that runs ever night at 11pm. The job completes at different times the next day. Anywhere from 8am to 4pm depending on other backup jobs.
I have a job summary report I built to show the files that were backed up. I need this report to launch after the specific subclient job has completed each day. I tried using the subclient post job script but because its a job summary report it does not show the files just backed up because the job is still open.
Need suggestion or direction how to get Commvault to check and notice when the backup has completed and run report.
Thank you
Best answer by Mike Struening
Hi @anonymouse !  You could run the backup for this subclient via a Workflow and trigger the report to run only after the backup job has completed.
Check out the built in operations (like ‘decision’) that can help this happen:
https://documentation.commvault.com/11.26/essential/131495_predefined_activities_for_workflows.html
Forum|alt.badge.img+23
