How to invoke/run a custom report from workflow, if we have the Equivalent API for it
  • June 13, 2024
  • 59 views
Forum|alt.badge.img+8
I have customized report (from Backup Job Summary report)
which has the information of certain jobs with for ex:
the report has a table which contains the following columns
Jobid, subclient, job status, start time, end time
I have added a schedule to this report to generate csv format file at a specific time.
If have to run this report from workflow, which API shall i use?
  • June 13, 2024
@alligator ,
You would need to follow the steps in our documentation.
https://documentation.commvault.com/2023e/essential/rest_apis_for_reports.html
Edward J Holowienka
