Library and Drive Report
  • November 26, 2024
  • 53 views
Does the information below in the report (see red square) mean that the backup size from that particular media agent is over 18TB?
Best answer by ErickOR
I’m going to answer my own question here from what I found.
The column I have in the red square displays that the media agent processed OVER 18TB of data “managed or transferred during the backup operations” in ONE 24hr period...apparently while processing less that 1 job in the same 24hr period. Additionally, the report cannot tell you an hourly number for whatever reason.
The reason for my question was how in the world can I process that much data on a media agent.
Running the report today, apparently this same MA, “managed or transferred during the backup operations” over 495TB in one 24hr period.
Maybe one day we can find out if this report is accurate. I don’t think it is.
  • November 27, 2024
Hi ​@ErickOR
The column highlighted in red represents the size of backup jobs processed by the Media Agent per day.
It reflects the total volume of data managed or transferred during the backup operations but does not imply that the Media Agent is storing more than 18 TB of data
Refer Data view document for more details : https://documentation.commvault.com/11.20/default_data_views_for_library_and_drive_report.html
  • December 2, 2024
