looking for sql view or direct sql table
  • Jul 17, 2023 2:23 PM UTC
  • 103 views
Forum|alt.badge.img+5
to joing 2 simple thing ….i want to see job from particular SP and connected media (tapes) to it ...i have jobs in SP and media ..but how to connect them :)
sub-question is any dictionary with CV tables / views with  info what fields is about ….or better how they are joined as keys between tables ?
Best answer by Nutan Pawar G
@Marcin_CF
Good Day!
You can use the jobs in storage policy copies report to view the jobs and its barcode
https://cloud.commvault.com/webconsole/softwarestore/store.do#!/135/660/26149
Note: “Barcode” column can be added by clicking on settings→ columns
Coming to your second question, there is no directory that displays the tables information.
Instead, you can copy the equivalent API and use them.
Kindly let me know if this helps?
@Marcin_CF
Good Day!
  • Nov 21, 2024 7:40 AM UTC
1 year later i will ask easier question on that above
is any way by PS or direct SQL query (table or view)  to show just all jobs in particular copy of particular storage policy  ...no more need tapes etc ….just basic thing jobs in specific spcopy ...if will be status of tat job (mean copied or in progress or planned) will be super
