Mass Subclient creation
  • October 10, 2024
  • 95 views
We have around 500 clients that backup a specific directory with a short retention. We now need a longer retention for a specific folder (10 years). As we can’t have different retentions for different folders in a plan, we need to create a second subclient on every existing clients and associate it with a long retention plan.
I’m trying to figure out if there is a simple way to mass create those subclients at a client group level or if I need to script it with qcreate or Rest Api commands.
Best answer by christopherlecky
Couple of different ways to go about it.
The easiest is using subclient policies.
  1. Create subclient policy.
  2. Create Group containing the clients you wish to modify.
  3. Associate subclient Policy to the Group.
Sureshkumar S
Hi @jxbarb ,
Good day!
To create subclient on multiple clients using qcommand
Ref : https://documentation.commvault.com/2023e/expert/creating_windows_file_system_subclient_from_command_line_interface_01.html
Sureshkumar S
christopherlecky
Explorer
Forum|alt.badge.img+21
  • October 11, 2024
Thanks a lot.
christopherlecky
Explorer
No problem.
