MediaAgent Hardware Refresh - problems using Replace MediaAgent app
  • May 11, 2023
  • 283 views
hi Community,
 i’m trying to refresh my MediaAgent by installing a new physical RHEL 8 server.
I followed the procedure described here:
https://documentation.commvault.com/11.26/expert/149337_migrating_to_new_mediaagent_using_replace_mediaagent_app.html
but the job “Move Mount Path” failed with message “Failure Reason:[File Read error happened on source MediaAgent, this could be due to some other process is accessing the file. Please resume the job after some time.]”
I’m sure to had followed the procedure step-by-step, and i checked if other job was running during the Workflow and was not. But now my doubt is about the process.
The app is created to change only the MediaAgent server and the backend storage could remain the same. Right?
Thanks in advanced
Regards
Alex
Emils
  • May 15, 2023
Hi @Alex_G
Thanks for reaching out, how are the libraries presented to the MediaAgents?
Is it SAN, NAS, DAS?
I would recommend skipping the Move MountPath if SAN.
  • May 15, 2023
Hi @Emils,
 thanks for your reply.
The library is NAS, a flex group volume NetAPP mounted via nfs on both MA.
I suspected something about the possibility to skip the “move” action, and i tried to run again the workflow but there isn’t any possibility to skip the move process
Regards
Alex
Emils
  • May 18, 2023
Hi @Alex_G I would recommend raising a support case, as this type of library should not cause an actual move but a configuration update.
  • February 20, 2025
I have the same issue, whereby I want the migrate tool to allow me to skip the move of my iscsi disks.  Does any one know what what the behaviour of the migration tool is now?
