Migrating backup vendor archives - is there a plan for other than file system data?
  • Jul 11, 2024 7:46 AM UTC
  • 48 views
Henk22
Hi all,
In the 2024E release I read something about migrating data from other backup vendors to Commvault. Unfortunately this can only be done for file ystem data (the the moment). Is there a plan to migrate other data (databases, VM's) too? That would be a complete solution when a customer wants to migrate from another vendor to Commvault
Hopefully we have some information on this! Thanks in advance for the answer
Kind regards,
Henk
Hello @Henk22
Can you link what you are referring about the file system and i can look further into it from there.
Kind regards
Albert Williams
