Not enough details in Storage Policy Copy Details API :(
  • April 16, 2025
  • 117 views
Hi folks,
I need to amend storage policy copy details (using API), particularly this block:
I need to change the value of streams number..
The GET request I use to obtain storage policy copy details:
<webservice>/V2/StoragePolicy/{storagePolicyId}/Copy/{copyId}
However, looks like this parameter is missing in the response 😒
Best answer by Alex T
Oki folks, as usual, this info is not available in official API manual, however this parameter is perfectly described in XML manual:
Updating Media Configurations of a Copy
element: numberOfStreamsToCombine
with JSON structure:
    "storagePolicyCopyInfo": {
        "numberOfStreamsToCombine": 20,
        "copyFlags": {
            "multiplexSourceStreams": 0,
            "combineStreams": 1
Guys, I am new here, on forum, is there any way to tag someone from CV so they can fix their API manual, or it is not going to work like this? 😊
Hi ​@Alex T,
Could you please try to fetch the "combineStreams" for SP copy using the API to Get Storage Policy Copy Details- API
url = "https://CommandCenterHostName/commandcenter/api/V2/StoragePolicy/:storagePolicyId/Copy/:copyId"
Response like:
"copyFlags": {
    "roundRobbinDataPath": 1,
    "combineStreams": 1,
    "storePlainText": 1,
    "autoAddDataPaths": 1
And then try updating the combineStreams for SP Copy referring to the Update Storage Policy Copy Details -API
Dheeraj Shetty
  • April 17, 2025
Hi ​@Dheeraj Shetty
that is how my copyFlags looks like:
        "copyFlags": {
            "preserveEncryptionModeAsInSource": 1,
            "storeKeyOnMedia": 1,
            "multiplexSourceStreams": 1,
            "autoAddDataPaths": 1,
            "lastFull": 1
So is you can see number 8 (see my screenshot) is missing..
And doing some experiments i found that combineStreams is responsible for that flag:
However, looks like there is parameter “combineStreams” but only in PUT method 🙄 (Update Storage Policy Copy Details):
so basically you can modify it, but can not get it... I will test “combineStreams” today
  • April 17, 2025
Oh , i posted the same parameter, my bad…
And yes i just tested it, it recognizes only 1 or 0 in this parameter, so combineStreams is definitely not the “Combine source data streams to”
  • April 17, 2025
        "copyFlags": {
            "combineStreams": 1
