Object Storage Deletion Authorisation Workflow
  • December 4, 2022
  • 103 views
CV has kincly provided a pre-built client deletion authorisation approval workflow for virtual machine clients.
There isn’t a pre-built workflow for objectstore clients (e.g. Azure FIles objects) - I’m wondering if that’s because it’s not possible or it’s just not a popular request(!) - has anyone done anything with this/can comment on whether it’s possible?
Thanks.
Best answer by Damian Andre
My guess is that it would be a rare ask - VMs generally have owners in the business while file clients are generally are owned by an IT organization. Not always the case but typically.
I don't see why this would not be possible. It might even be a little easier than VMs since there is a virtual client at play in that scenario too.
  • December 5, 2022
  • December 5, 2022
Thanks, Damian - I’ve had a bit of a look at the delete client VM workflow and am finding the syntax of the workflow a bit impenetrable (and the CV docs aren’t the most helpful).
Any resources out there you recommend that might help me work through building a new workflow?  Ta.
