PowerShell Invoke-RestMethod for API Call
  • August 19, 2022
  • 7961 views
LukeBrett
Apprentice
Hi guys,
I have been using the CVPowerShellSDK_v1 and was able to create tools and scripts for our team. Now, I would like to move a step further and make my own API Calls with the Invoke-RestMethod in PowerShell but I am having a hard time to get started (disclaimer: I have a backgrouind as a sysadmin, not a web developper). I played around with Postman, API Explorer, I went through the documentation on the subject and tried different ways to interact with APIs in PowerShell but I still haven’t succeeded in retrieving data with a simple GET method.
I am at the point where I need a little help from friends to move forward. So, if anyone could help me to make a simple GET request through PowerShell with an output in JSON format, I would greatly appreciate and would be able to figure out the rest by myself.
Let’s say, for example, I want to retrieve the information of the EmailServer and create a simple function like Get-CVEmailServer.
In curl, the request would be:
curl -X GET "https://myserver/webconsole/api/EmailServer" -H "accept: application/json"
And the Response body :
{ "enableSSL": false, "smtpServer": "commserve.com", "filterInvalidEmails": false, "startTLS": false, "smtpPort": 25, "useAuthentication": false, "useEncryptedMailServer": false, "maxMailServerSize": 10240, "timeout": 30000, "senderInfo": { "senderName": "LukeBrett", "senderAddress": "lukebrett@mycompany.com" } }
Now, I have been trying different things around the following command, but did not get anything I could work with... :
$headers = @{}
$headers.Add("Accept", "application/json")
$headers.Add("Content-Type", "application/json")
$creds = Get-Credential
Invoke-RestMethod -Uri 'http://myserver/webconsole/api/EmailServer' -Method Get -Credential $creds -SkipCertificateCheck -Headers $headers
I know I might be missing some formatting expressions here and other details, but if someone could provide me with an example, it would really be a game changer for me. Thanks a lot!
Best answer by Jos Meijer
I am not experienced with powershell, but if you go to this link:
https://api.commvault.com/#a2b7504f-69d1-4965-87c9-630bc0dbc54e
And then at the top at the section Language select PowerShell - RestMethod
It will translate from Curl to what you need, at least an example is given.
In this case:
$headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
$headers.Add("Authtoken", "QSDK token would be auto set after POST Login is called.")
$response = Invoke-RestMethod 'http://WebConsoleHostName/webconsole/api/EmailServer' -Method 'GET' -Headers $headers
$response | ConvertTo-Json
the response would be something like:
"enableSSL": false,
"smtpServer": "smtp.commvault.com",
"smtpPort": 25,
"maxMailServerSize": 0,
"userInfo": {
"userName": ""
"senderInfo": {
"senderName": "Yash",
"senderAddress": "Commvault@GreenValley.test.com"
Hope this helps 🙂
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • August 19, 2022
In this case:
"enableSSL": false,
"smtpPort": 25,
"userInfo": {
"userName": ""
"senderInfo": {
Hope this helps 🙂
LukeBrett
Apprentice
  • August 20, 2022
Thanks @Jos Meijer! :) I wasn’t aware that I could change the language to PowerShell on the API page. I was able to do the test I suggested. The token part needed to be adapted a little so I’ll post it here :
# How to connect and get a token
$body = "{`n `"password`": `"Password_in_Base64`",`n `"username`": `"admin`",`n `"timeout`" : 30`n}"
$response = Invoke-RestMethod 'http://WebServerName/webconsole/api/Login' -Method 'POST' -Headers $headers -Body $body
$token = $response.token
# Getting the EmailServer
$headers.Add("Authtoken", $token)
$response = Invoke-RestMethod 'http://WebServerName/webconsole/api/EmailServer' -Method 'GET' -Headers $headers
"enableSSL": false,
"smtpServer": "MySmtpServer",
"startTLS": false,
"smtpPort": 25,
"timeout": 30000,
"senderInfo": {
"senderAddress": "lbrett@test.com"
Jos Meijer
  • August 20, 2022
Your welcome @LukeBrett
Good to hear it's working now 🙂
Onno van den Berg
Forum|alt.badge.img+24
@LukeBrett it might be worth looking into the V2 version of the Powershell SDK. It delivers more backend functionality and includes by default a cmdlet that allows you to set the SMTP server. I have raised some questions if the missing functionality from V1 is ported to V2 so we can all focus on one generic version.
See: https://www.powershellgallery.com/packages/CommvaultPowerShell/0.2.6
