Powershell module
  • Oct 22, 2025 8:49 AM UTC
  • 80 views
Henke
Explorer
What are other users of Commvault powershell module opinion of the module.
I am disapointed. I was hoping for a well working modle, but it is a struggle. Commands  aren’t logical, not following powershell best practices. Help is minimal and examples of commands are missing.
No where I can find that it is work in progress.
My opinion is that Commvault need to either put an effort in developing the module to a working module or state that it is a “Work in progress -- beta” module.
//Henrik
Hi ​@Henke , we will check this out. is there a specific set of commands you are working with, if so pls let me know.
Henke
Explorer
  • Oct 23, 2025 7:00 AM UTC
Hello ​@MaheshPrakash
I’ve listed two examples.
I guess what annoyes me is that it isn’t intuitive.
one example:
Get-CVSQLDatabase -Name xds, gives a result
Get-CVSQLDatabaseDetail -name xds, errors out
Write-Error: C:\Program Files\WindowsPowerShell\Modules\CommvaultPowerShell\0.3.4\custom\oldsdk\Submit-CVRESTRequest.ps1:68
Line |
  68 |                  ValidateResponse $response $output $ValidateProperty
     |  Status:  Message: Response status code does not indicate success: 500 (). ErrorMessage:  {   "errorMessage":
     | "Exception caught when database details retrieval with error [Invalid request, both instance and database ID is
     | required for this API.].",   "errorCode": 101 } RecommendedAction:
Another example
Get-CVAlert
notifType      : 131073
description    : Default alert for Commvault appliance and RefArch HyperScale platform monitoring
organizationId : 0
createdTime    : 1697538690
status         : 2049
creator        : @{name=admin; id=1}
alertType      : @{name=HyperScale platform and hardware monitoring alert rule; id=44}
alert          : @{name=HyperScale platform alert; id=158}
organization   :
alertCategory  : @{name=Custom Rules; id=9}
PS > Get-CVAlertCustomRuleDetail -AlertRuleId 158
Get-CVAlertCustomRuleDetail_Get: The server responded with a Request Error, Status: NotFound
PS> Get-CVAlertCustomRuleDetail -AlertRuleId 9
PS > Get-CVAlertCustomRuleDetail -AlertRuleId 44
