Prevent Synthetic Full Backups
  • August 7, 2024
  • 123 views
Need for 1 day prevent synthetic full backups to start
Changing it in all schedules seems a little bit not best practice
Any way to disable it globally and turn it back again?
Best answer by Scott Moseman
What is the reason for disabling Synth Fulls for 1 day?
My suggestion would be to see if this could be done with a Blackout Window.
Scott
Hello @evgenich
You are able to disable the schedule completely for the day:
https://documentation.commvault.com/2023e/expert/disabling_schedule.html
But this wont target just synthetic full jobs.  I'm not sure of a way to achieve this for the entire environment.
Kind regards
Albert Williams
Scott Moseman
Forum|alt.badge.img+23
  • August 9, 2024
Scott
Aplynx
  • August 27, 2024
You could disable schedules or activity under the CommServe.
You could create an automatic group to pick up specific machines, IDA types, etc and disable activity.
