Python SDK - releases and versions
  • Mar 20, 2025 2:54 PM UTC
  • 215 views
Forum|alt.badge.img+2
Hi all,
I am trying to automate our Commvault platform, and have been using the cvpysdk package a bit - however, I am missing some information.
First of all, are there any release notes available for the different versions/releases of the package? I can not find anything really in pypi or in github.
Secondly, I can also see that the releases are versioned as 11.32, 11.34, 11.36, 11.38, is this directly correlating to what version of Commvault software you are using or what release should one use? Is it possible to use 11.38 on a 11.32 platform or should I be expecting operational difficulties?
Lastly, what python versions are supported?
Thank you in advance,
Daniel
  • Mar 24, 2025 5:54 AM UTC
Hi ​@danbj, unfortunately we don't have a release notes as of today, but we do have cvpysdk docs which you can refer to, from here: https://commvault.github.io/cvpysdk/.
Yes, the version of cvpysdk do directly correlate to the version of software you are using, please use 11.32 version of cvpysdk for 11.32 of the Commvault software, and additionally we do support up to 3 service packs of backward compatibility.
What python versions are supported? We support Python 3.9 and above, but we recommend using Python 3.9.
Chinmay
