Removing client from subclient (not working) and commands execution log
  • May 8, 2024 4:19 PM UTC
  • 88 views
I am trying to remove a client from subclient (PowerShell), and it works in most of cases, however I came across with a strange case when automation just does not work, for no reason (the target client stays in the subclient)
I tried to use both methods I know:
Remove-CVVirtualMachine and qoperation execute
both with “error code: 0” on exit 😐
Also, I would deeply appreciate if anyone share the info under witch module in “process manager > logging” commands execution log can be found
Best answer by Alexey Tesov
In case someone else having the same issue, here is the answer to a question “how to remove a client from subclient”
I solve it by using: qoperation execute -af $xml_path
here is an VERY important fragment of XML request
<vmContent>
            <children equalsOrNotEquals="1" displayName="$target" type="$client_type" name="$client_hash" />
</vmContent>
where $client_hash is strGUID of target client and $client_type is integer. I was not able to find anywhere in CV documentation that name parameter is critical for deleting clients with type 9 -- “Virtual Machine” 😑
Here is the full XML block:
$xmltemplate =@"
<?xml version='1.0' encoding='UTF-8'?>
<App_UpdateSubClientPropertiesRequest>
<association>
<entity appName="Virtual Server" instanceName="VMware" backupsetName="$BackupsetName" clientName="$VCenterName" subclientName="$SubclientName" />
</association>
<subClientProperties>
<vmContentOperationType>DELETE</vmContentOperationType>
<vmContent>
</vmContent>
</subClientProperties>
</App_UpdateSubClientPropertiesRequest>
  • May 9, 2024 9:03 AM UTC
Oki, I found the logs:
qcommand
qscript
qsdk
however deletion still not working
  • Aug 22, 2024 2:25 PM UTC
<vmContent>
</vmContent>
$xmltemplate =@"
<association>
</association>
<vmContent>
</vmContent>
