Report: "Merge Duplicate Clients"
  • January 6, 2023
  • 399 views
Forum|alt.badge.img+2
is it correct that the report “Merge Duplicate VM Clients” shows only duplicated VMs?
Some time ago I was able to see all duplicates:
  • VM - VM
  • VM - FileSystem
Now the report doesn’t show duplicate VM - FileSystem clients, in the console I can see them.
Tested on 11.28.37 / 11.24.69 with the APP from Download.
What would be the way to identify duplicate VM - FileSystem clients?
Merge only by CLI?
Sergej
Forum|alt.badge.img+18
  • January 6, 2023
Good afternoon.  Can you please tell me what Feature Release you were on when you were seeing the now changed behavior.  This report shows duplicate VMs only.
  • January 9, 2023
Hi Orazan,
I’m not sure, it was 1 or 2 years ago, maybe SP22.
