Rest Api for Schedule Policy
  • April 5, 2022
  • 117 views
Forum|alt.badge.img+2
Hello Team,
I need to fetch data for schedule policy and using below apis *a* and *b* for that
  1. https://documentation.commvault.com/v11/essential/48764_rest_api_get_schedule_policy.html. Tried with http://<webservice>/SchedulePolicy on browser but this throws 404 error code.
whereas
  1. http://<webconsole>/webconsole/api/Schedules?clientId=2 this works fine without any error.
Can you please help me with below queries:
  1. Are these both a and b api(s) return same data?
  2. Need help on why “404 Not found” message while hitting api ‘a’ on browser?
Best answer by RMcG
Hi Maggie
The HTTP 404 Not Found means the url you are trying is incorrect. Eg no resource found.
The API /SchedulePolicy does exist so please double check that the url you are trying is correct.
“Tried with http://<webservice>/SchedulePolicy on browser but this throws 404 error code.”
Should be http://<webservicehost>/webconsole/api/SchedulePolicy
@RMcG may be able to help with this one 😇
  • April 7, 2022
Hi Maggie
