Rest API: Storage Utilization per Client
  • September 6, 2021
  • 132 views
Forum|alt.badge.img+2
Hello Guys,
i’m looking for a way to determine how much storage is in use by some of my clients, but i can’t find it.
I found the Top 5 biggest servers by using the Command Center Dashboard so the information must be there.
Can anyone give me a hint where to look?
Best answer by Stuart Painter
Hi @Bjoern_SRZC
Thanks for the question.
We have Client Storage Utilization by Storage Policy Copy report, does this fit with your requirements?
I see you’ve tagged this post with REST API, but I haven’t been able to find a built in REST API call that will return this data.
We do have a capability for you to access report data via REST APIs for Reports.
Stuart
Hi @Bjoern_SRZC
Stuart
