Retrieving External Groups list using qCommands?
  • May 19, 2021
  • 92 views
Forum|alt.badge.img+2
I would like to retrieve all Domains and Organisation External groups using the qCommands.
I tried to do it using the following procedure but I can only retrieve the CommCell User Groups and not the external one:
https://documentation.commvault.com/commvault/v11/article?p=8261_1.htm
Do you think it is possible to retrieve the configured external groups using qCommands or it is possible only using the API request “/UsersAndGroups” ?
Thank you in advance for your answer.
John
Best answer by Anthony Lordi
Hello @JohnADP !
The qcommand you mentioned using would be the only one we have that will generate a list of users/user groups. It only generating a list of internal user/user groups is expected behavior at this time. The rest API request /UsersAndGroups as well as /UserGroup are what you will need to use to provide the full list of internal and external user/user groups. Is there a specific reason you’re looking to do this via qcommand compared to the REST API request?
Anthony
Anthony Lordi
Hello @JohnADP !
Anthony
