sangfor HCI support in commvault
  • June 14, 2022
  • 947 views
heloo everyone,
can anybody tell that sangfor HCI is support for VM backup ?
Best answer by Jos Meijer
Ahh Openstack is an option indeed 😀
You can deploy a VSA within an Openstack tenant and talk to the API endpoints in order to make snapshots of the instance (VM), but there is no CBT in place resulting in VM disks receiving a full CRC scan on each backup. If you have large VM's this will take a lot of time.
For other type of backups you will have to rely on agent based actions.
Please note that depending on the infrastructure specifications you could encounter a bottleneck on the networkers for Openstack.
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • June 14, 2022
I have not seen any support yet for Sangfor HCI, here are the current supported hypervisors:
https://documentation.commvault.com/11.26/essential/119371_supported_hypervisors.html
  • June 15, 2022
an rest API to integrate VM backup because sangfor HCI using open stack  for its hypervisor.?
Jos Meijer
  • June 16, 2022
  • June 16, 2022
please explain more for above statement thanks!
Jos Meijer
  • June 16, 2022
Here is the information regarding Openstack Instance (VM) backup:
https://documentation.commvault.com/2022e/essential/121687_openstack.html
Depending on your network configuration you will need to assign a network or provide routing to the network for the VSA to communicate with the Openstack API endpoints to initiate the necessary activities on API components regarding Compute, Image, Network, Storage etc
