Script to add VMs to Subclient
  • February 10, 2023
  • 187 views
Hello everyone,
I am looking for a script to add Vmware VMs to subclient.  I have been poking around Powershell SDK/Commands but i am not successful so far with the latest Powershell v32 SDK
Eventually i need to feed VM Names from csv file and loop through but for now just testing with a single VM.
Add-CVVirtualMachine -ClientName myVCenter -SubclientName z_Subclient_0400PM -EntityType VM -Entity my-vmname
Getting following error:
“Get-CVVirtualMachine : A parameter cannot be found that matches parameter name 'Name'.
At C:\Program Files\WindowsPowerShell\Modules\CommvaultPowerShell\0.2.11\custom\oldsdk\Add-CVVirtualMachine.ps1:166 char:61
+ ...                         $vmProps = Get-CVVirtualMachine -Name $entity ...
    + CategoryInfo          : InvalidArgument: (:) [Get-CVVirtualMachine], ParameterBindingException
    + FullyQualifiedErrorId : NamedParameterNotFound,Get-CVVirtualMachine
  • February 10, 2023
Thank you for reporting this error.
We will fix this soon.
This cmdlet is available in the old SDK : https://github.com/Commvault/CVPowershellSDK as well.
You can uninstall the existing version and install through this github which will work for your requirement for now.
  • February 10, 2023
thank you! problem is that, the old sdk works for a single VM but fails to add multiple VM in the list well.
Add-CVVirtualMachine -ClientName myVCenter -SubclientName z_Subclient_0400PM -EntityType VM -Entity my-vmname, my_vmname2, my_vmname3
Any ETA when will get it fixed?
Thank you!
  • February 14, 2023
@JnaneshD do you know if this is fixed in 0.2.13 ?
  • February 15, 2023
Hi @Just Learning ,
It is not been fixed yet. We will work on this and update.
