Scripts for client capacity check
  • June 19, 2023
  • 84 views
I want to collect or check how much capacity is consumed each client. is there any scripts or automated way rather than check every client’s job history?
Best answer by Sebastien Merluzzi
Hi @Niamunn ,
Have you check our License Summary and Backup Summary Report:
https://documentation.commvault.com/2022e/expert/40116_license_summary_report_overview.html
https://documentation.commvault.com/11.28/expert/39614_backup_job_summary_report.html
Sebastien Merluzzi
  • June 19, 2023
@Sebastien Merluzzi  I want to have the client consumed backup capacity for each client. but from job history, it is time consuming. So I am looking for any reporting method by which i can have this. or any script that is useful. I already found a method for using script, “backendstorage” is the required script that should be in script folder in commserver but for my case it is not there. but all the other scripts were there. So I am looking for a solution for this. Your response is really appreciable.
Niamun
@Niamunn ,
Scripts are located in different places. That one is by default in
C:\Program Files\Commvault\ContentStore\Base\DBUpgrade\CommServer\MainUpgrade\DBStoredProcedure
Best Regards,
Sebastien
