Silent/Automatic Software Agent Deployment via Script for Endpoints Laptops and desktops
  • May 31, 2024
  • 111 views
I'm working on a project where I need to deploy a software agent to endpoint devices. The requirement is for the deployment to be completely silent and automatic, initiated by a script running on the user's device. Here are the specific details:
  • The script will download the agent from a cloud storage location (e.g., S3 bucket).
  • The downloaded agent will then be automatically installed on the user's device.
  • The entire process should be seamless and require no user interaction.
Can someone please help me with the script or any other approach I can take here?
Hello @Akshay1998
The following should go over everything you are looking to achieve:
https://documentation.commvault.com/2023e/essential/performing_silent_installation_for_end_user_laptop_package.html
Please advise if there is a section that you have some further questions about and I can assist.
Kind regards
Albert Williams
