I’m looking a manner to get the IndexCache status using Command Line or RestAPI or qscript, qcommand … in order to automate some maintenance tasks
Commvault version is 11.28.
Status of IndexCache using CLI/RestAPI/ ... is there a way to get it ?
Best answer by Navneet Singh
You can go to health report and go to the index cache location.
Copy the rest API from the report and pull the details.
