Use REST-API inside a workflow
  • July 11, 2025
  • 135 views
Hi together,
I would like to use REST API calls inside a workflow. Unfortunately, I do only find the opposite information in the documentation (how to use workflows with REST API).
Can someone give me a starting point for this topic?
Best regards.
Michael
Best answer by MaheshPrakash
Pls check HttpClient Activity in the workflow section.
Predefined Activities for Workflows
Hi MaheshPrakash,
thank you. That ist great! I appreciate this.
Regards.
Michael
