use RESTAPI in a powershell script
  • January 27, 2022
  • 2619 views
Hi All,
i need help to create a powershell script using REST API command.
i don’t found a lot of documentation for the specific use of REST API in powershell.
in the community in have found a sample for POST LOGIN
$headers = @{}
$headers.add("Accept", "application/json")
$headers.add("Content-Type","application/json")
$username = "user"
$password = "passwordtoencode"
$encodePassword = [convert]::ToBase64String([Text.Encoding]::UTF8.GetBytes($password))
$body = @{username=$username;password=$encodePassword;}
$response = Invoke-RestMethod 'http://hostname/webconsole/api/Login' -Method POST -Headers $headers -Body $($body | ConvertTo-Json )
$response
But somenone have sample for all kind of REST API sample ?
Thank in advance
Christophe
Best answer by Mike Struening
@christophe , have you checked out the examples on https://api.commvault.com/ ?
That page has pretty much everything (and if it doesn’t, let me know and I’ll get it addressed) :nerd:
Onno van den Berg
Forum|alt.badge.img+24
@christophe I would recommend looking into the PowershellSDK which simplifies the consumption of the APIs while using Powershell. And if you are running FR26 already then I have good news because development release a brand new version today!
V1 version: https://github.com/Commvault/CVPowershellSDK
V2 version (requires FR26): https://github.com/Commvault/CVPowershellSDKV2
V1 documentation → https://documentation.commvault.com/11.24/essential/101893_commvault_powershell_module.html
